It is currently Mon Jul 07, 2025 3:47 pm
PostPosted: Wed Oct 14, 2009 11:30 pm
First name: Mark
Last Name: Schrier
State: Washington
Todd,
Thanks for persevering and getting this up and running. 25 minutes be a long time, but a screwed up guitar is forever. Looking forward to the grand finale.
Regards,
Mark
A world without music would Bb.
PostPosted: Mon Dec 28, 2009 2:23 pm
City: Benton Harbor
Todd -
These videos are great - especially for a first-timer.
Question: Is the epoxy being applied to the bare wood? or is something else put on first?
thanks!
PostPosted: Mon Dec 28, 2009 3:04 pm
sea.of.white wrote:
Todd -
thanks!
IMPO It is best to apply epoxy to the bare wood. If a sealer is used first there is a more than slight chance that the epoxy will not adhere to the sealer. (Depending on the sealer used) Almost all sealers will adhere to cured epoxy resin but epoxy resin can be a bit pickier about what it adheres to.)
PostPosted: Mon Dec 28, 2009 3:33 pm
City: Benton Harbor
good to know, thanks for the tip
PostPosted: Sat May 01, 2010 6:12 am
First name: mark
Last Name: aron
City: goffstown
State: nh
Zip/Postal Code: 03045
I noticed that you have the body connected to stand.Is this something you made and gould you pass along how to make it? Thanks Mark Aron
PostPosted: Sat May 01, 2010 12:34 pm
Last Name: Abercrombie
Mark-
I think the guitar body is 'prepped' for a bolt-on neck. It's pretty easy to just bolt a 'stick' where the neck will eventually attach, and then hold the 'stick' in a vise.
The stick makes a good 'handle' for holding the guitar when finishing; a loop of cord/wire through the stick end is handy for hanging up the guitar.
PostPosted: Sun May 02, 2010 6:10 am
First name: mark
Last Name: aron
City: goffstown
State: nh
PostPosted: Mon May 10, 2010 6:29 pm
First name: mark
Last Name: aron
City: goffstown
State: nh
This whole process makes an extemely good case on doing bolt on necks.The bolt on area on the body can be used for many uses during the building process.By the way,I used z-poxy to fill the pores on my second build.the body is black locust with dark walnut trim and the neck is dark walnut with curly maple laminated in the middle.
Mark Aron
PostPosted: Tue Jun 01, 2010 1:27 pm
Todd:
Just wanted to slip in a word of thanks for your work and presence on the OLF. The videos help a ton.
Danny R. Little
PostPosted: Fri Jun 11, 2010 4:49 am
Thank you for the video.
Does this epoxy filling apply only to wood with very small pores or also to woods with large pores?
PostPosted: Mon Jun 14, 2010 9:35 am
Thank you Todd for your answer.
I will try this next time.
